How to copy version releases from one project to another using Automation for Jira
How to copy version releases from one project to another using Automation for Jira.
Jira Cloud
The rule will retrieve the version releases from the source project using REST API, using the response we can create versions in the destination project using the automation action create version. The components needed are:
A screenshot to illustrate the flow of the rule:
Updated on September 25, 2025
