Groovy script in Insight automation rules not executed due to not in whitelist, missing file or lack permission
Common Problems
The automation rule to trigger a Groovy script was triggered as expected but the script wasn't executed.
The following appears in the insight_automation.log.
Scenario 1 - script path is not whitelisted
2021-12-01 15:15:59,576 [insight-event-8] | GroovyScriptAction, got absFilePath: /Users/jira/jira-home/atlassian-jira-servicedesk-4.20.0/scripts/Move Object to Archive.groovy
2021-12-01 15:15:59,577 [insight-event-8] | GroovyScriptAction, not in whitelist, exit, absFilePath: /Users/jira/jira-home/atlassian-jira-servicedesk-4.20.0/scripts/Move Object to Archive.groovyScenario 2 - incorrect script path/script is not found
2021-12-01 15:15:59,577 [insight-event-8] | GroovyScriptAction, missing file, absFilePath: /Users/jira/jira-home/atlassian-jira-servicedesk-4.20.0/scripts/Move Object to Archive.groovyScenario 3 - Script file/folder permission
2021-12-01 15:50:50,076 [insight-event-4] | GroovyScriptAction, got absFilePath: /Users/jira/jira-home/atlassian-jira-servicedesk-4.20.0/scripts/Move Object to Archive.groovy
2021-12-01 15:50:50,078 [insight-event-4] | Execute groovy script: /Users/jira/jira-home/atlassian-jira-servicedesk-4.20.0/scripts/Move Object to Archive.groovy
2021-12-01 15:50:50,222 [insight-event-4] | AutomationRuleGroovyScriptAction, Unexpected error: /Users/jira/jira-home/atlassian-jira-servicedesk-4.20.0/scripts/Move Object to Archive.groovy can not be read. Check the read permission of the file "/Users/jira/jira-home/atlassian-jira-servicedesk-4.20.0/scripts/Move Object to Archive.groovy" (/Users/jira/jira-home/atlassian-jira-servicedesk-4.20.0/scripts/Move Object to Archive.groovy).
java.lang.RuntimeException: /Users/jira/jira-home/atlassian-jira-servicedesk-4.20.0/scripts/Move Object to Archive.groovy can not be read. Check the read permission of the file "/Users/jira/jira-home/atlassian-jira-servicedesk-4.20.0/scripts/Move Object to Archive.groovy" (/Users/jira/jira-home/atlassian-jira-servicedesk-4.20.0/scripts/Move Object to Archive.groovy).
at groovy.lang.GroovyCodeSource.<init>(GroovyCodeSource.java:118)
at groovy.lang.GroovyShell.evaluate(GroovyShell.java:621)
at com.riadalabs.jira.plugins.insight.services.core.impl.GroovyServiceImpl.evaluate(GroovyServiceImpl.java:86)
at com.riadalabs.jira.plugins.insight.services.automation.action.AutomationRuleGroovyScriptAction.doActionSafe(AutomationRuleGroovyScriptAction.java:99)
at com.riadalabs.jira.plugins.insight.services.automation.action.AbstractInsightAutomationAction.doAction(AbstractInsightAutomationAction.java:107)
at com.riadalabs.jira.plugins.insight.services.automation.rule.impl.AutomationRuleEngineImpl.executeAction(AutomationRuleEngineImpl.java:669)
at com.riadalabs.jira.plugins.insight.services.automation.rule.impl.AutomationRuleEngineImpl.executeActions(AutomationRuleEngineImpl.java:654)
at com.riadalabs.jira.plugins.insight.services.automation.rule.impl.AutomationRuleEngineImpl.matchConditionAndExecuteActions(AutomationRuleEngineImpl.java:453)
at com.riadalabs.jira.plugins.insight.services.automation.rule.impl.AutomationRuleEngineImpl.handleScheduledEvent(AutomationRuleEngineImpl.java:351)
at com.riadalabs.jira.plugins.insight.services.automation.event.AutomationRuleEventListener.onScheduledEvent(AutomationRuleEventListener.java:112)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at com.google.common.eventbus.Subscriber.invokeSubscriberMethod(Subscriber.java:87)
at com.google.common.eventbus.Subscriber$SynchronizedSubscriber.invokeSubscriberMethod(Subscriber.java:144)
at com.google.common.eventbus.Subscriber$1.run(Subscriber.java:72)
at com.atlassian.sal.core.executor.ThreadLocalDelegateRunnable.run(ThreadLocalDelegateRunnable.java:34)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)Diagnosis
Any Insight versions
Diagnostic Steps
For scenario 1 and 2, the status of the rule will be a green check mark even though the script actually failed to be executed. For scenario 3, the status of the rule will be a red exclamation mark as shown in the screenshot below.
Scenario 1
The path to the script is not whitelisted
Scenario 2
The path to the script is incorrect
Scenario 3
The script is not readable by all users especially the user running Jira
Resolution
Scenario 1
Each groovy script has to be whitelisted at Administration > Manage apps > Insight Whitelist. The full path to the script must be provided like in the example below.
Scenario 2
Ensure that the full path to the script is provided correctly in the THEN action of the rule
Scenario 3
Ensure that the directory and the subdirectories where the script(s) is are readable by all users and also executable by the user running Jira. If the script(s) is in a folder resides in Jira home, follow How to fix directory permissions in Linux for Jira Server or How to fix directory permissions in Windows for Jira Server to fix all directories at once. An example of the directory and file permissions.
$ ls -al ~/jira-home/atlassian-jira-servicedesk-4.11.0/scripts
total 8
drwxr-x--- 3 jira staff 96 Nov 24 21:47 .
drwxr-xr-x 21 jira staff 672 Dec 1 15:48 ..
-rw-r--r-- 1 jira staff 2421 Nov 24 21:47 Move Object to Archive.groovyWas this helpful?
