Drag and drop is not working due to plugin reloadibility problem
Symptoms
Sometime, the drag and drop is not working after upgrading Greenhopper plugins. Whenever you try to drag, you can monitor a javascript exception in the background:
TypeError: C is null [Stop with this error] ...e:$F("searchType")})}if(!B){Boards.closePopups();Boards.working()}else{GH.Util.s... com.py...mmon.js (Line 6) TypeError: C is null [Stop with this error] ...e:$F("searchType")})}if(!B){Boards.closePopups();Boards.working()}else{GH.Util.s... com.py...mmon.js (Line 6) TypeError: C is null [Stop with this error] ...e:$F("searchType")})}if(!B){Boards.closePopups();Boards.working()}else{GH.Util.s... com.py...mmon.js (Line 6) TypeError: C is null
The upgrade process is succeeded from the atlassian-greenhopper.log. You can verify it by looking for the following trace
********************************************************************************* Atlassian GreenHopper v6.x #cc4371e11036 built 2013-04-18T11:44:43.987+08:00 - plugin started. Get Agile! *********************************************************************************
The plugin is unable to load after the ugprade process. The following error appear in atlassian-jira.log:
2013-03-06 11:44:52,904 http-8080-42 ERROR xxx.xxxx.xxxx 704x1193865x1 h0997g 95.89.218.204,10.10.10.11 /secure/IssueAction.jspa [jira.event.issue.IssueEventListenerHandler] Exception thrown from listener [com.pyxis.greenhopper.jira.listeners.CacheEvictionListener] : It appears that a call has been made to BridgeServiceLocator when it is not initialised. This may indicate a plugin reloadability problem?? java.lang.IllegalStateException: It appears that a call has been made to BridgeServiceLocator when it is not initialised. This may indicate a plugin reloadability problem?? at com.atlassian.greenhopper.service.BridgeServiceLocator.getInstance(BridgeServiceLocator.java:147) at com.pyxis.greenhopper.jira.listeners.CacheEvictionListener.evict(CacheEvictionListener.java:88) at com.pyxis.greenhopper.jira.listeners.CacheEvictionListener.issueUpdated(CacheEvictionListener.java:32) at com.atlassian.jira.event.issue.AbstractIssueEventListener.workflowEvent(AbstractIssueEventListener.java:94
Resolution
Perform a full JIRA Indexing to make sure the plugins upgraded completely.
Updated on September 26, 2025
