Create Multiple Jira Issues Based on a Custom Number Field Using Automation
Learn to create multiple Jira Cloud work items automatically using the value from a custom number field.
Use automation to create multiple work items in a loop
Select a trigger for your automation rule.
Add an action: Create variable. This is to initialize the looping values.
Variable name: varLoopValues
Smart value:
NULL
Add a second action: Create variable. This will replace the old value with your looping values.
Smart value:
{{varLoopValues.rightPad(varLoopValues.length.plus(
issue.description
), "X").remove("NULL").replaceAll("X","X,").substringBeforeLast(",")}}
In this example, the smart value uses the Description field (
issue.description
). Replace it with your custom field name.
Add a branch: Advanced branch.
Smart value:
{{varLoopValues.split(",")}}
Variable name: varLoopVariable
Inside the branch, add a final Action: Create issue. This will create multiple issues based on the number of loops.
Import this rule to your cloud site
Save the following code as a .json file in a text editor. Then, import the automation rule to your Jira Cloud site:
{"cloud":true,"rules":[{"id":19931846,"clientKey":"eb42e4c8-9ed8-387e-91a0-9d734ba6c1c1","name":"Create Multiple Jira Issues Based on a Custom Number Field","state":"ENABLED","description":"","authorAccountId":"70121:646025f4-3216-4734-a4c3-eca3f5c3f050","actor":{"type":"ACCOUNT_ID","value":"557058:f58131cb-b67d-43c7-b30d-6b58d40bd077"},"created":1718274007299,"updated":1718277909886,"trigger":{"id":"469460657","component":"TRIGGER","parentId":null,"conditionParentId":null,"schemaVersion":2,"type":"jira.manual.trigger.issue","value":{"inputFromUsers":false,"inputPrompts":[],"groupIds":false,"groups":[],"issueFilter":null,"jQLFilter":null},"children":[],"conditions":[],"connectionId":null},"components":[{"id":"469460658","component":"ACTION","parentId":null,"conditionParentId":null,"schemaVersion":1,"type":"jira.create.variable","value":{"id":"_customsmartvalue_id_1718274490850","name":{"type":"FREE","value":"varLoopValues"},"type":"SMART","query":{"type":"SMART","value":"NULL"},"lazy":false},"children":[],"conditions":[],"connectionId":null},{"id":"469460659","component":"ACTION","parentId":null,"conditionParentId":null,"schemaVersion":1,"type":"codebarrel.action.log","value":"1st {{varLoopValues}}","children":[],"conditions":[],"connectionId":null},{"id":"469460660","component":"ACTION","parentId":null,"conditionParentId":null,"schemaVersion":1,"type":"jira.create.variable","value":{"id":"_customsmartvalue_id_1718274575063","name":{"type":"FREE","value":"varLoopValues"},"type":"SMART","query":{"type":"SMART","value":"{{varLoopValues.rightPad(varLoopValues.length.plus(issue.description), \"X\").remove(\"NULL\").replaceAll(\"X\",\"X,\").substringBeforeLast(\",\")}}"},"lazy":false},"children":[],"conditions":[],"connectionId":null},{"id":"469460661","component":"ACTION","parentId":null,"conditionParentId":null,"schemaVersion":1,"type":"codebarrel.action.log","value":"2nd {{varLoopValues}}","children":[],"conditions":[],"connectionId":null},{"id":"469460662","component":"BRANCH","parentId":null,"conditionParentId":null,"schemaVersion":1,"type":"jira.smart.values.branch","value":{"id":"_customsmartvalue_id_1718274795198","name":{"type":"FREE","value":"varLoopValues"},"type":"SMART","query":{"type":"SMART","value":"{{varLoopValues.split(\",\")}}"},"lazy":false},"children":[{"id":"469460663","component":"ACTION","parentId":"469460662","conditionParentId":null,"schemaVersion":10,"type":"jira.issue.create","value":{"operations":[{"field":{"type":"ID","value":"summary"},"fieldType":"summary","type":"SET","value":"{{varLoopValues}}"},{"field":{"type":"ID","value":"description"},"fieldType":"description","type":"SET","value":null},{"field":{"type":"ID","value":"project"},"fieldType":"project","type":"SET","value":{"value":"current","type":"COPY"}},{"field":{"type":"ID","value":"issuetype"},"fieldType":"issuetype","type":"SET","value":{"type":"COPY","value":"current"}}],"advancedFields":null,"sendNotifications":false},"children":[],"conditions":[],"connectionId":null}],"conditions":[],"connectionId":null}],"canOtherRuleTrigger":false,"notifyOnError":"FIRSTERROR","projects":[],"labels":[],"tags":[{"id":65859699,"tagType":"IS_RULE_UPDATED","tagValue":"true"}],"ruleScope":{"resources":["ari:cloud:jira:16e89efc-ab25-43f8-84d7-0997692fc8c7:project/10075"]},"ruleHome":{"ruleLifecycleHome":{"locationARI":"ari:cloud:jira:16e89efc-ab25-43f8-84d7-0997692fc8c7:project/10075"},"ruleBillingHome":{"locationARI":"ari:cloud:jira-servicedesk::site/16e89efc-ab25-43f8-84d7-0997692fc8c7"}},"writeAccessType":"UNRESTRICTED","collaborators":[],"billingType":"NORMAL"}]}
