Create Jira issue Assets automation rule not working
Problem
Assets Automation rules "Create Jira issue" does not create a Jira issue
By enabling the debug package for Assets Automation , The following appears in the insight_automation.log
2022-04-07 16:18:26,220 [http-nio-127.0.0.1-8080-exec-785 url: /rest/insight/1.0/automation/rule/11/events/run; user: psubramaniyan] | AutomationRuleCreateJiraIssueAction, Unexpected error: com.atlassian.jira.util.SimpleErrorCollection@285051f1[errors={customfield_20991=Strategy is required.},errorMessages=[],reasons=[VALIDATION_FAILED]] com.riadalabs.jira.plugins.insight.common.exception.JiraServiceInsightException: com.atlassian.jira.util.SimpleErrorCollection@285051f1[errors={customfield_20991=Strategy is required.},errorMessages=[],reasons=[VALIDATION_FAILED]] at com.riadalabs.jira.plugins.insight.services.jira.JIRAServiceImpl.createIssue(JIRAServiceImpl.java:577) at com.riadalabs.jira.plugins.insight.services.jira.JIRAServiceImpl.createIssue(JIRAServiceImpl.java:530) at com.riadalabs.jira.plugins.insight.services.automation.action.AutomationRuleCreateJiraIssueAction.doActionSafe(AutomationRuleCreateJiraIssueAction.java:64) at com.riadalabs.jira.plugins.insight.services.automation.action.AbstractInsightAutomationAction.doAction(AbstractInsightAutomationAction.java:107) at com.riadalabs.jira.plugins.insight.services.automation.rule.impl.AutomationRuleEngineImpl.executeAction(AutomationRuleEngineImpl.java:675)
  • Jira Service Management Data Center with Assets
Diagnostic Steps
  • There is an Assetst Automation rule to create a Jira issue with certain criteria is met
  • The user (either the logged-in user or the user that you select for running scheduled events) has at least the Assets Users role for the schema and permissions to create a Jira issue within the project selected
  • There is a Jira field or a custom field set to be required
Assets has a fixed form for creating issues with Automation rules. It does not allow to include other custom fields. If you have a custom field or Jira field set to be required on creation, the automation rule will fail.
Workaround
You could create a Jira issue using Assets Automation with the required fields as follows:
  1. Use Execute Groovy Script
    1. This action allows a triggered rule to execute a Groovy Script
  2. Use HTTP request
    1. This action allows a triggered rule to make HTTP request and add the mandatory values to the API's payload
Updated on September 26, 2025
