Copy attachments when linking Jira Data Center issues using Automation
When an issue link is created, you want to copy attachments from the current issue (also called the trigger issue) to the linked issue using an automation rule.
This article applies to Jira Data Center only. For Jira Cloud, please see Sync Comments and Copy Attachments in Linked Jira Cloud Work Items.
Create an automation rule
  • Navigate to Administration (⚙ ) > System > Global Automation if you're using tickets from different projects.
    • That way, you can select the Scope as All projects or Multiple projects.
    • If issue links will be created between issues of the same project, you can select Single project under Scope.
  • Create the rule with the following components:
    • Set the Trigger: Choose "Issue Linked" as the trigger and configure the trigger to activate when an issue is linked with your specific link type (for example, "Blocks"). You can also select multiple link types.
    • Add Condition (Optional): If you want to ensure that the rule only applies to specific issue types, for example, add a condition and use the "Issue fields condition" to check if it is the intended issue type.
    • New branch: Choose "Branch rule / related issues" to perform actions on the linked issue. In the branch, select "Linked issues" and specify the link type(s).
    • Add the Action: Now add an action inside this branch: "Edit issue", and configure this action to copy attachments from the trigger issue to the linked issue.
  • Save and test the rule.
The completed rule should look similar to this:
Automation rule, components: WHEN: Issue Linked, IF: Issue type equals Task, FOR: linked issues relates to, Then: Edit issue fields attachments
Related article: Automation rule to copy a field from a Parent to a Child issue as soon as the Child issue is linked to it
Updated on September 25, 2025
