Comment Headers not rendering on Jira Issues after Upgrade
It has been observed that "Comment Headers" on Jira tickets does not render properly. This is generally seen after Jira upgrade.
Jira Data Center
Following a recent Jira upgrade, the "Comment Headers" on the ticket does not render properly. Example:
$18n.getText ('issue.tabpanels.comment.action.header, Suserformat.formatUserkey(SauthorKey, 'profileLinkActionHeader', "commentauthor_$(comment.id)_$!(suffix)"),ScreatedDate) - $/18n.getText('common.concepts.edited*)
It has been observed that sometimes the "macros.vm" does not get updated during the upgrade, which causes this problem.
Begin by extracting the tar.gz file of the upgraded Jira version to some other location. You can also download the tar.gz file from official download site Official download site.
Navigate to below path of your Jira install location and verify the "macros.vm" file placed in this location is updated and the content matches with the file present in the extracted tar.gz above. You can use commands like diff, md5sum or any text compare editors to compare the files.
$JIRA_INSTALL/atlassian-jira/WEB-INF/classes/templates/plugins/JiraWas this helpful?
