An automation rule to notify when an issue is moved to another project
If you have a use case where you would want to be notified if an issue is moved to another project (not intended project)
Create an automation rule with the following components:
Trigger: Issue moved from any project to any project:
Condition:
issue.project.key doesn't contain equals("Projectkey 1", "Projectkey 2") (Here we can update all the project key list)
Reference article: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-conditional-logic/
Action: Send an email to move it to the appropriate projects.
Updated on September 26, 2025
