Accessing moved issue through original issue key or attempting to move issues in Jira Data Center fails
Problem
When attempting to access a moved issue by its original Issue Key, as well as triggering the Move function on Jira, the following stack trace is displayed on the interface:
Sorry, we had some technical problems during your last operation.
Request assistance
Copy the content below and send it to your JIRA Administrator
Technical details
Log's referral number: ec54d7fe-ed3d-47da-980e-c00af4dda984
Referer URL: https://yourjirainstance.com/issues/?jql=issuekey%20%3DPROJKEY-865\\
java.lang.ClassFormatError: com/atlassian/jira/issue/MovedIssueKey
at com.atlassian.jira.entity.MovedIssueKeyFactory.build(MovedIssueKeyFactory.java:20) [classes/:?]Looking over at the atlassian-jira.log, we can see the following stack trace:
2018-09-04 15:18:33,607 http-nio-8080-exec-661 url:/secure/GHGoToBoard.jspa username:jirauser ERROR [o.a.c.c.C.[.[localhost].[/].[action]] Servlet.service() for servlet [action] in context with path [] threw exception [Filter execution threw an exception] with root cause
at com.atlassian.jira.entity.MovedIssueKeyFactory.build(MovedIssueKeyFactory.java:12)
at com.atlassian.jira.entity.SelectQueryImpl$ExecutionContextImpl.forEach(SelectQueryImpl.java:231)
at com.atlassian.jira.entity.SelectQueryImpl$ExecutionContextImpl.consumeWith(SelectQueryImpl.java:214)
at com.atlassian.jira.entity.SelectQueryImpl$ExecutionContextImpl.singleValue(SelectQueryImpl.java:191)
at com.atlassian.jira.issue.util.MovedIssueKeyStoreImpl.getMovedIssueId(MovedIssueKeyStoreImpl.java:43)
at com.atlassian.jira.issue.managers.DefaultIssueManager.findMovedIssue(DefaultIssueManager.java:283)
at com.atlassian.jira.issue.managers.DefaultIssueManager$IssueFinder.getIssue(DefaultIssueManager.java:961)
at com.atlassian.jira.issue.managers.DefaultIssueManager.getIssueByKeyIgnoreCase(DefaultIssueManager.java:354)
at com.atlassian.jira.issue.managers.RequestCachingIssueManager.getIssueByKeyIgnoreCase(RequestCachingIssueManager.java:91)
at com.atlassian.jira.jql.util.JqlIssueSupportImpl.getIssue(JqlIssueSupportImpl.java:70)
at com.atlassian.jira.jql.util.JqlIssueSupportImpl.getIssue(JqlIssueSupportImpl.java:62)
at com.atlassian.jira.jql.query.IssueIdClauseQueryFactory.createQueryForKey(IssueIdClauseQueryFactory.java:163)
at com.atlassian.jira.jql.query.IssueIdClauseQueryFactory.createQueryForNotEmptyValue(IssueIdClauseQueryFactory.java:156)
at com.atlassian.jira.jql.query.IssueIdClauseQueryFactory.createQuery(IssueIdClauseQueryFactory.java:148)
at com.atlassian.jira.jql.query.IssueIdClauseQueryFactory.createPositiveEqualsQuery(IssueIdClauseQueryFactory.java:134)
at com.atlassian.jira.jql.query.IssueIdClauseQueryFactory.handleEquals(IssueIdClauseQueryFactory.java:129)
at com.atlassian.jira.jql.query.IssueIdClauseQueryFactory.getQuery(IssueIdClauseQueryFactory.java:68)
at com.atlassian.jira.jql.query.ContextAwareQueryVisitor.visit(ContextAwareQueryVisitor.java:97)
at com.atlassian.jira.jql.query.ContextAwareQueryVisitor.visit(ContextAwareQueryVisitor.java:25)
at com.atlassian.query.clause.TerminalClauseImpl.accept(TerminalClauseImpl.java:143)
at com.atlassian.jira.jql.query.ContextAwareQueryVisitor.visit(ContextAwareQueryVisitor.java:71)
at com.atlassian.query.clause.OrClause.accept(OrClause.java:28)
at com.atlassian.jira.jql.query.QueryVisitor.createQuery(QueryVisitor.java:51)
at com.atlassian.jira.jql.query.DefaultLuceneQueryBuilder.createLuceneQuery(DefaultLuceneQueryBuilder.java:29)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.search(LuceneSearchProvider.java:231)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.searchOverrideSecurity(LuceneSearchProvider.java:135)
... 2 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
at com.sun.proxy.$Proxy493.searchOverrideSecurity(Unknown Source)
... 2 filtered
at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:136)
at com.atlassian.greenhopper.service.issue.IssueDataServiceImpl.findImpl(IssueDataServiceImpl.java:150)
at com.atlassian.greenhopper.service.issue.IssueDataServiceImpl.findOverrideSecurity(IssueDataServiceImpl.java:78)
at com.atlassian.greenhopper.customfield.epiclink.EpicLinkResolver.findEpicIssueIdsByEpicKeyOrLabel(EpicLinkResolver.java:103)
at com.atlassian.greenhopper.customfield.epiclink.EpicLinkResolver.getQuery(EpicLinkResolver.java:58)
at com.atlassian.greenhopper.customfield.epiclink.EpicLinkEqualityQueryFactory.getQuery(EpicLinkEqualityQueryFactory.java:200)
at com.atlassian.greenhopper.customfield.epiclink.EpicLinkEqualityQueryFactory.handleIn(EpicLinkEqualityQueryFactory.java:146)
at com.atlassian.greenhopper.customfield.epiclink.EpicLinkEqualityQueryFactory.createResult(EpicLinkEqualityQueryFactory.java:102)
at com.atlassian.greenhopper.customfield.epiclink.EpicLinkEqualityQueryFactory.createQueryForMultipleValues(EpicLinkEqualityQueryFactory.java:60)
at com.atlassian.greenhopper.customfield.searcher.GhGenericClauseQueryFactory.getQuery(GhGenericClauseQueryFactory.java:68)
at com.atlassian.greenhopper.customfield.epiclink.EpicLinkClauseQueryFactory.getQuery(EpicLinkClauseQueryFactory.java:31)
at com.atlassian.jira.jql.query.ContextAwareQueryVisitor.visit(ContextAwareQueryVisitor.java:55)
at com.atlassian.query.clause.AndClause.accept(AndClause.java:28)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.createLuceneQuery(LuceneSearchProvider.java:272)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.getHitCount(LuceneSearchProvider.java:177)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.searchCountOverrideSecurity(LuceneSearchProvider.java:121)
... 2 filtered
at com.sun.proxy.$Proxy493.searchCountOverrideSecurity(Unknown Source)
... 2 filtered
at com.atlassian.greenhopper.service.issue.SearchServiceImpl.searchCountOverrideSecurity(SearchServiceImpl.java:166)
at com.atlassian.greenhopper.service.rapid.RapidViewLocationServiceImpl.doesSprintMatchQuery(RapidViewLocationServiceImpl.java:366)
at com.atlassian.greenhopper.service.rapid.RapidViewLocationServiceImpl.getRapidViewsForSprint(RapidViewLocationServiceImpl.java:231)
at com.atlassian.greenhopper.web.rapid.RapidViewLocationResolverFactory$SprintRapidViewLocationResolver.getRapidViewsForObject(RapidViewLocationResolverFactory.java:203)
at com.atlassian.greenhopper.web.rapid.RapidViewLocationResolverFactory$SprintRapidViewLocationResolver.getRapidViewsForObject(RapidViewLocationResolverFactory.java:185)
at com.atlassian.greenhopper.web.rapid.BoardDispatchAction._doGoToBoard(BoardDispatchAction.java:116)
at com.atlassian.greenhopper.web.rapid.BoardDispatchAction.doGoToBoard(BoardDispatchAction.java:61)
... 2 filtered
at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70)
at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56)
... 2 filtered
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63)
... 7 filtered
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
... 52 filtered
at com.atlassian.servicedesk.internal.web.ExternalCustomerLockoutFilter.doFilter(ExternalCustomerLockoutFilter.java:56)
... 4 filtered
at com.atlassian.greenhopper.jira.filters.ClassicBoardRouter.doFilter(ClassicBoardRouter.java:62)
... 7 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 47 filtered
at com.atlassian.ams.shipit.servlet.filter.AbstractThreadFilter.runWithChangedThreadName(AbstractThreadFilter.java:71)
at com.atlassian.ams.shipit.servlet.filter.AbstractThreadFilter.doFilter(AbstractThreadFilter.java:53)
at com.atlassian.ams.shipit.servlet.filter.AbstractThreadFilter.doFilter(AbstractThreadFilter.java:37)
... 14 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:80)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:78)
... 36 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 5 filtered
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.lambda$invokeFilterChain$0(CustomerContextSettingFilter.java:181)
at com.atlassian.servicedesk.internal.utils.context.ReentrantThreadLocalBasedCodeContext.rteInvoke(ReentrantThreadLocalBasedCodeContext.java:134)
at com.atlassian.servicedesk.internal.utils.context.ReentrantThreadLocalBasedCodeContext.runOutOfContext(ReentrantThreadLocalBasedCodeContext.java:87)
at com.atlassian.servicedesk.internal.utils.context.CustomerContextServiceImpl.runOutOfCustomerContext(CustomerContextServiceImpl.java:64)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.outOfCustomerContext(CustomerContextSettingFilter.java:174)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilterImpl(CustomerContextSettingFilter.java:130)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilter(CustomerContextSettingFilter.java:121)
... 4 filtered
at com.atlassian.jwt.internal.servlet.JwtAuthFilter.doFilter(JwtAuthFilter.java:32)
... 8 filtered
... 4 filtered
... 3 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 29 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 28 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748Diagnosis
JIRA Data Center
In this case, we've also noticed the following, which might be one of the reasons for the cache failure:
2018-08-29 11:11:21,958 ehcache-replicator-19 ERROR [c.a.j.c.cache.ehcache.BlockingParallelCacheReplicator] Exception on replication of remove. Exception creating connection to: 100.99.16.212; nested exception is:
java.net.SocketException: Too many open files. Cache: com.atlassian.jira.crowd.embedded.ofbiz.OfBizUserDao.userAttributesCache Peer: com.atlassian.jira.crowd.embedded.ofbiz.OfBizUserDao.userAttributesCache
java.rmi.ConnectIOException: Exception creating connection to: 100.99.16.212; nested exception is:
at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:631)
at sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:216)
at sun.rmi.transport.tcp.TCPChannel.newConnection(TCPChannel.java:202)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:130)
at net.sf.ehcache.distribution.RMICachePeer_Stub.remove(Unknown Source)
at com.atlassian.jira.cluster.cache.ehcache.BlockingParallelCacheReplicator.lambda$replicateRemovalNotification$1(BlockingParallelCacheReplicator.java:163)
at com.atlassian.jira.cluster.cache.ehcache.BlockingParallelCacheReplicator.lambda$null$3(BlockingParallelCacheReplicator.java:203)
at com.atlassian.jira.cluster.cache.ehcache.ClassLoaderSwitchingRunnable.run(ClassLoaderSwitchingRunnable.java:18)
at java.util.concurrent.CompletableFuture$AsyncRun.run(CompletableFuture.java:1626)
Caused by: java.net.SocketException: Too many open filesCause
This is caused by a cache replication failure. The node is not replicating the cache correctly, thus causing the issues to not be found and the move operation to fail.
Workaround / Resolution
Restart the node with the broken replication. This will ensure that the cache will be replicated from a healthy node and the operations will be fixed.
