500 page error when using project issue filter
Problem
After click on the Project issue filter (such as Assign to Me link), JIRA will throw 500 error page. It will happen if user click on the "Issues > Search for issues" menu as well.
The following will appears in the web browser:
Referer URL: <base-url>/browse/<project>/?selectedTab=com.atlassian.jira.jira-projects-plugin:issues-panel java.lang.NoClassDefFoundError: org/apache/commons/lang3/StringUtils java.lang.NoClassDefFoundError: org/apache/commons/lang3/StringUtils at com.atlassian.jira.components.query.DefaultSearcherService.getEditHtml(DefaultSearcherService.java:474) at com.atlassian.jira.components.query.DefaultSearcherService.getValueResults(DefaultSearcherService.java:259) at com.atlassian.jira.components.query.DefaultSearcherService.getSearchResults(DefaultSearcherService.java:180) at com.atlassian.jira.components.query.DefaultSearcherService.searchWithJql(DefaultSearcherService.java:174) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
  • JIRA 6.3.15
Diagnostic Steps
  • Check if any bundled plugin jar file store at the installed-plugins/plugins folder via JIRA home directory.
There is a jar file overwrite the default bundled plugin version.
Resolution
Remove the bundled plugin jar file from the installed-plugins/plugins folder via JIRA home directory and restart JIRA to resolved the problem.
Updated on September 26, 2025
