Using variables to calculate dates with Automation for Jira Data Center
If you try using A4J's standard syntax for Smart Values to manipulate date and time values using variables, you may come across issues with the rule results where the resulting date will be null.
Automation for Jira Data Center.
This occurs because the new and current A4J syntax does not support the use of variables in their date and time functions.
However, the old syntax available in the Archived date functions does support the use of variables.
Examples of Variable date calculation:
1 2 3 {{#now}}func=plusDays({{Variable}}){{/}} {{#triggerIssue.Target Start.toDate}}func=plusBusinessDays({{Variable}}){{/}}
Updated on February 25, 2025
