User is not able to create jira issue in a project even with the required permission to create ticket
The user is not able to create a Jira issue in a project even when user has required permission to create a ticket.
Jira Cloud
On the 'Create Issue' screen, when selecting 'Create', after filling out the form, the user is presented with an error stating: "We couldn't create the issue. The default assignee does NOT have ASSIGNABLE permission OR Unassigned issues are turned off."
This is potentially do to a permissions issue on the Project. You can verify this in the browser dev tools. You should you see an HTTP 400 response code with a header response similar to:
"errorMessages": [],
"errors":
{ "assignee": "The default assignee does NOT have ASSIGNABLE permission OR Unassigned issues are turned off."
Should you see this response, as an administrator, check the project settings:
On the sidebar, tap 'Project Settings' and check the 'Details' tab
There, ensure that the 'Project Lead' and 'Default Assignee' fields have valid entries.
If the 'Default Assignee' is not a valid assignable user, the issue will not be created. In this case, update the project settings to either 'Unassigned' or to a valid user and then 'Save'. This should address the error and allow you to create the issues in that project.
