Jira is in continuous maintenance mode due to ORA-01878
Jira fails to take the index snapshot from the shared-home and on every restart triggers a full reindex to bring it out of Maintenance mode.
Jira Data Center 8.x and above.
Copying the indexing data from another node by navigating to the indexing page fails with the error ORA-01878. Many occurrences of the following warning message are observed in the atlassian-jira.log
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
2023-12-04 16:33:57,402+0200 main ERROR [c.a.jira.cluster.DefaultClusterManager] Current node: node1. Couldn't recover index even though it had been found in shared. Current list of other nodes: [node2]
com.querydsl.core.QueryException: Caught SQLDataException for select WORKLOG_VERSION.worklog_id, WORKLOG_VERSION.parent_issue_id, WORKLOG_VERSION.update_time, WORKLOG_VERSION.index_version, WORKLOG_VERSION.deleted
from worklog_version WORKLOG_VERSION
where WORKLOG_VERSION.update_time > current_timestamp + interval '-133911' second
at com.querydsl.sql.DefaultSQLExceptionTranslator.translate(DefaultSQLExceptionTranslator.java:50)
Caused by: java.sql.SQLDataException: ORA-01878: specified field not found in datetime or interval
at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:494)
Caused by: Error : 1878, Position : 157, Sql = select WORKLOG_VERSION.worklog_id, WORKLOG_VERSION.parent_issue_id, WORKLOG_VERSION.update_time, WORKLOG_VERSION.index_version, WORKLOG_VERSION.deleted
where WORKLOG_VERSION.update_time > current_timestamp + interval '-133911' second, OriginalSql = select WORKLOG_VERSION.worklog_id, WORKLOG_VERSION.parent_issue_id, WORKLOG_VERSION.update_time, WORKLOG_VERSION.index_version, WORKLOG_VERSION.deleted
where WORKLOG_VERSION.update_time > current_timestamp + interval '-133911' second, Error Msg = ORA-01878: specified field not found in datetime or interval
... 92 more
The above error may results in due to SQLDataException as the update_time field is not correctly set.
Similar error could results due to invalid DST change date for comment_version, issue_version and worklog_version table as well
Always back up your data before making any database modifications. If possible, test any alter, insert, update, or delete SQL commands on a staging server first.
Use the below query SQL1 to check for missing/null in update_time in worklog_version
SQL1
1
select * from worklog_version where UPDATE_TIME is NULL;
Also, fetch the invalid records i.e. Issues created/updated during DST changes using below query SQL2, the below SQL is for US/Pacific, You might want to change the dates for the DST for other timezone based on your the Jira timezone in below SQL2.
SQL2
1
2
3
4
5
6
SELECT worklog_id, * FROM Worklog_VERSION
WHERE UPDATE_TIME BETWEEN TIMESTAMP '2024-03-10 01:59:00' AND TIMESTAMP '2024-03-10 03:01:00'
OR UPDATE_TIME BETWEEN TIMESTAMP '2023-03-12 01:59:00' AND TIMESTAMP '2023-03-12 03:01:00'
OR UPDATE_TIME BETWEEN TIMESTAMP '2022-03-13 01:59:00' AND TIMESTAMP '2022-03-13 03:01:00'
OR UPDATE_TIME BETWEEN TIMESTAMP '2021-03-12 01:59:00' AND TIMESTAMP '2021-03-12 03:01:00'
OR UPDATE_TIME BETWEEN TIMESTAMP '2020-03-13 01:59:00' AND TIMESTAMP '2020-03-13 03:01:00';
Stop Jira servers to perform an update on Database tables.
For the missing/null values found in SQL1, set the update_time to the previous day using the SQL3
SQL3
1
update WORKLOG_VERSION set update_time = TO_DATE('<currentDate-1>','DD-MM-YY') where WORKLOG_VERSION.update_time < TO_DATE('<currentDate-1>','DD-MM-YY') and UPDATE_TIME is NULL;
For DST invalid records fetched in SQL2, you may find the
worklog_id
and add it in below query SQL4 to update.
SQL4
1
update WORKLOG_VERSION set update_time = TO_DATE('<currentDate-1>','DD-MM-YY') where WORKLOG_VERSION.update_time < TO_DATE('<currentDate-1>','DD-MM-YY') and worklog_id in (<worklog_id>) -- from above SQL2
Restart Jira
