Custom Field Required in Jira Resulting in Integration Issues with Jira Align
When trying to create a new Feature in Jira Align, the error below appears on the audit logs despite all mappings to Jira being set correctly:
Unable to create issue: customfield_25920: Story Type is required.Solution
According to this article Jira and Jira Align Integration: Jira Issue Field Best Practices more specifically to Best Practice #2 section;
Best Practice #2: Fields that are NOT synced between Jira Align and Jira cannot be marked as required in Jira. Why:If an item is created in Jira Align and there is a required field in Jira that does not sync with Jira Align, the sync will fail and the item will not be created in Jira. This is because Jira is looking for the connector to pass this info from Jira Align but it doesn't exist in Jira Align. Since Jira sees this as a required field for creation, it will not create it. This is most common with custom fields.
A minimum list of fields that can be synced from Jira Align to Jira. There could be more fields listed.
Epics
Name
Description
Estimate (Points)
Acceptance Criteria
Assignee
Status
Fix Version (if used)
Labels
Issue Type
Reporter
Program Increment (optional custom field)
Parent Jira Epic Name (optional custom field)
Why? (optional custom field)
Stories
Description
Estimate (Points)
Parent Epic
Acceptance Criteria
Assignee
Status
Issue Type
Labels
Epic Link
Reporter
Sprint
Assigned Team (optional custom field)
Sub-Tasks
Description
Assignee
Parent Story
Reporter
Bug
Description
Estimate (Points)
Assigned Team
Sprint
Assignee
Priority
Status
State
Fix Version
Review the list and confirm any fields that are marked as required are fields that can be synced. Reference list above. If fields are not synced via the connector, they must be changed to Optional.
