Problem processing revisions from repo <REPOSITORY> due to class com.cenqua.fisheye.rep.DbException - Problem getting diff information for revXXXX
Symptoms
The following appears on the FeCruLogs and you are using the SVN Native Client:
2012-06-18 11:31:03,385 ERROR [IncrementalPinger1 <REPOSITORY>] fisheye.app BaseRepositoryScanner-handleSlurpException - Problem processing revisions from repo <REPOSITORY> due to class com.cenqua.fisheye.rep.DbException - Problem getting diff information for rev789 com.cenqua.fisheye.rep.DbException: Problem getting diff information for rev789 ... Caused by: com.cenqua.fisheye.svn.diff.SvnDiffException: Exception processing diff for revision 789 ... Caused by: com.cenqua.fisheye.svn.diff.SvnDiffParsingException: Unexpected line in overall diff .. 2012-06-18 11:31:03,385 ERROR [IncrementalPinger1 Publications] fisheye.app BaseRepositoryScanner-handleSlurpException - Repository scanner paused.
We´ve already seen this kind of behavior before when using the SVN Native Client.
Resolution
As a workaround you will have to rollback to SVNKit. Remove the Svn Client Configuration (Native Subversion Client) from Fisheye and after that restart it, now the problem should be resolved.
Updated on September 25, 2025
