Manual Index Process Hangs at 99 Percent and Index Queue Fails to Flush
Symptoms
  1. A manual reindexing of the site hangs at 99% for a long period of time and attachment extractors have already been disabled for diagnostic purposes.
  2. The recently updated macro is no longer displaying updates.
For Cause 1 the following appears in the atlassian-confluence.log:
2010-08-11 03:00:00,095 ERROR [DefaultQuartzScheduler_Worker-7] [org.quartz.core.ErrorLogger] schedulerError Job (DEFAULT.IndexQueueFlusher threw an exception. org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: com.atlassian.bonnie.LuceneException: com.atlassian.bonnie.LuceneException: java.io.IOException: There is not enough space on the disk]] at org.quartz.core.JobRunShell.run(JobRunShell.java:214) at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:520) \* Nested Exception (Underlying Cause) --------------- com.atlassian.bonnie.LuceneException: com.atlassian.bonnie.LuceneException: java.io.IOException: There is not enough space on the disk
Cause 1
The local disk that houses the Confluence Home folder is low on space and a new index cannot be built, nor can sequential additions be made by the Index Queue Flusher.
Resolution 1
  1. Free up space on the drive or migrate the home folder to a new disk space.
  2. Check to see that the <confluence-home>/backup folder is not overloaded. If it is, consider removing the backup zips and using the recommended Production Backup Strategy.
Cause 2
The tasklist macro creates a new page every time you edit or delete any content from the list.
Depending on the usage, this can render a page with thousand of versions, causing the index to fail and get stuck at some point causing index problems to the whole instance as result.
Resolution 2
Copy the page with the tasklist macro, delete the old page, purge the old page from space trash, and rename the new page. Then try indexing again.
Updated on September 25, 2025
