JIRA Macro Issues does not render properly for logins containing white spaces
Problem
When displaying JIRA Issues in a Confluence page, they will not render properly if the user login contains white spaces:
The following appears in the atlassian-confluence.log:
2014-05-12 11:41:58,239 ERROR [Jira macros executor:thread-4] [confluence.extra.jira.JiraIssuesMacro] throwMacroExecutionException Macro execution exception: -- referer: http://confluence:8090/ | url: /display/TES/Testing+Home | userName: admin | action: viewpage | page: 4030466 java.lang.IllegalArgumentException: Illegal character in query at index 208: http://jira:8080/sr/jira.issueviews:searchrequest-xml/temp/SearchRequest.xml?jqlQuery=key+in+%28TEST-3%29&returnMax=true&field=summary&field=type&field=resolution&field=status&field=link&xoauth_requestor_id=d luvison at java.net.URI.create(URI.java:859) at com.atlassian.sal.core.net.HttpClientProtocolConfig.changeHostConfigurationProtocol(HttpClientProtocolConfig.java:43) at com.atlassian.sal.core.net.HttpClientProtocolConfig.configureProtocol(HttpClientProtocolConfig.java:20) at com.atlassian.sal.core.net.HttpClientRequest.configureProtocol(HttpClientRequest.java:532) at com.atlassian.sal.core.net.HttpClientRequest.setUrl(HttpClientRequest.java:135) at com.atlassian.sal.core.net.HttpClientRequest.setUrl(HttpClientRequest.java:71) at com.atlassian.plugins.rest.module.jersey.JerseyRequest.setUrl(JerseyRequest.java:57) at com.atlassian.plugins.rest.module.jersey.JerseyRequest.setUrl(JerseyRequest.java:21) at com.atlassian.applinks.core.auth.ApplicationLinkRequestAdaptor.setUrl(ApplicationLinkRequestAdaptor.java:134) at com.atlassian.applinks.core.auth.ApplicationLinkRequestAdaptor.setUrl(ApplicationLinkRequestAdaptor.java:20) at com.atlassian.applinks.core.auth.oauth.twolo.impersonation.TwoLeggedOAuthWithImpersonationRequest.signRequest(TwoLeggedOAuthWithImpersonationRequest.java:43) at com.atlassian.applinks.core.auth.oauth.OAuthRequest.execute(OAuthRequest.java:42) at com.atlassian.confluence.extra.jira.DefaultJiraIssuesManager.retrieveXML(DefaultJiraIssuesManager.java:92) at com.atlassian.confluence.extra.jira.CacheJiraIssuesManager.retrieveXML(CacheJiraIssuesManager.java:41) at com.atlassian.confluence.extra.jira.DefaultJiraIssuesManager.retrieveXMLAsChannel(DefaultJiraIssuesManager.java:174) at com.atlassian.confluence.extra.jira.JiraIssuesMacro.populateContextMapForStaticSingleIssue(JiraIssuesMacro.java:753) at com.atlassian.confluence.extra.jira.JiraIssuesMacro.createContextMapFromParams(JiraIssuesMacro.java:595) at com.atlassian.confluence.extra.jira.JiraIssuesMacro.execute(JiraIssuesMacro.java:1492) at com.atlassian.confluence.extra.jira.executor.StreamableMacroFutureTask.call(StreamableMacroFutureTask.java:36) at com.atlassian.confluence.extra.jira.executor.StreamableMacroFutureTask.call(StreamableMacroFutureTask.java:15) at java.util.concurrent.FutureTask.run(FutureTask.java:262) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:745) Caused by: java.net.URISyntaxException: Illegal character in query at index 208: http://jira:8080/sr/jira.issueviews:searchrequest-xml/temp/SearchRequest.xml?jqlQuery=key+in+%28TEST-3%29&returnMax=true&field=summary&field=type&field=resolution&field=status&field=link&xoauth_requestor_id=d luvison at java.net.URI$Parser.fail(URI.java:2829) at java.net.URI$Parser.checkChars(URI.java:3002) at java.net.URI$Parser.parseHierarchical(URI.java:3092) at java.net.URI$Parser.parse(URI.java:3034) at java.net.URI.<init>(URI.java:595) at java.net.URI.create(URI.java:857) ... 23 more
The above symptom will not affect users that do not have white spaces in their username.
This is a bug with the Application links plugin being unable to handle the white spaces during the information change process. This is currently being tracked in APL-1195 - Failed to use application link with user name of non Latin character or space.
Confluence and JIRA does not allow a login containing white spaces, unless you pull those from an external directory (AD/LDAP). If you have a user from AD/LDAP that contains white spaces, you will see this bug when trying to render JIRA issues in a page.
Workaround
Change the username to remove the white spaces in AD/LDAP and synchronize within Confluence. If that is not feasible, make sure to vote for the bug mentioned above and add your thoughts to it.
Updated on September 25, 2025
