JIRA Issues Macro Does Not Work When Using JIRA as Trusted Application Due to 'org.springframework.dao.IncorrectResultSizeDataAccessException' Skip to End of Metadata
Symptoms
THe JIRA Issues Macro does not render results. The following appears in the atlassian-confluence.log:
2008-05-18 11:16:14,263 DEBUG [http-8040-Processor22] [sf.hibernate.type.StringType] nullSafeGet returning 'confluence:159392' as column: ALIAS .. 2008-05-18 11:16:14,315 DEBUG [http-8040-Processor22] [sf.hibernate.type.StringType] nullSafeGet returning 'confluence:159392' as column: ALIAS .. 2008-05-18 11:16:14,321 DEBUG [http-8040-Processor22] [sf.hibernate.type.StringType] nullSafeGet returning 'confluence:159392' as column: ALIAS 2008-05-18 11:16:14,324 ERROR [http-8040-Processor22] [renderer.v2.components.MacroRendererComponent] processMacro Unexpected error formatting macro: jiraissues -- url: /confluence/dwr/exec/WysiwygConverter.convertToPreview.dwr | userName: evgenyz org.springframework.dao.IncorrectResultSizeDataAccessException: Incorrect result size: expected 2, actual 3 at com.atlassian.confluence.security.persistence.dao.hibernate.HibernateKeyStoreDao.getKeyPair(HibernateKeyStoreDao.java:35)
Confluence is a trusted application for itself, therefore a second public key was created. When using the JIRA Issues macro, 3 keys (instead of 2) are retrieved from the database.
Resolution
Delete one of the public key entries in the KEYSTORE table. Start with a SELECT statement:
SELECT * FROM KEYSTORE;
Use a DELETE statement to delete the entry. If you delete too many entries, simply reset the trust in the user interface.
Updated on April 8, 2025
