How to filter automation rule in Automation for Jira
Currently Automation for Jira's audit log does not have a way to search/filter but we can do that by looking directly into the database.
Running the query below will show all rules executed successfully for a specific issue TST-123.
select AIAI."NAME", AI.* from jiradb.dbo."AO_589059_AUDIT_ITEM" AI join jiradb.dbo."AO_589059_AUDIT_ITEM_ASC_ITEM" AIAI on AI."ID" = AIAI."AUDIT_ITEM_ID" where AI."CATEGORY" = 'SUCCESS' and AIAI."NAME" = 'TST-123'
Updated on September 26, 2025
