How to fetch the latest worklog entry using Automation for Jira?
Fetching the latest worklog entry that has just been logged against an issue using Smart values in Automation for Jira.
As mentioned in Jira Smart Values -Issues the different smart values available for worklog are : {{worklog.comment}} {{worklog.started}} {{worklog.timeSpentSeconds}} Visibility is available when the worklog is restricted {{worklog.visibility}} {{worklog.visibility.type}} {{worklog.visibility.value}}
However, to fetch the only latest worklog entry, you can use the below smart value
{{issue.worklog.last.timeSpent}}
