How to clone an issue and update the customer request type using Automation for Jira
Clone issue and update the target clone ticket customer request type using Automation for Jira rules.
Configure the automation rule to look like this:
In the Rule details, please restrict to the source and target projects. For example:
SDS = source project
HD = target project
In the Edit issue fields action, please set the JSON format to look like this:
a. As you can see the "Customer Request Type" field is set to the GUID = "hd/46d6141f-a6ba-486a-a989-d67be7f760d1"
"fields":{
"Customer Request Type":"hd/46d6141f-a6ba-486a-a989-d67be7f760d1"
b. To find the customer request type guid, please run the following SQL query:
select
vp."KEY" as portal_key,
vp."NAME" as "project name",
vpf."KEY" as "customer request type guid",
vpf."NAME" as "customer request type name"
from "AO_54307E_VIEWPORT" vp
join "AO_54307E_VIEWPORTFORM" vpf on vp."ID" = vpf."VIEWPORT_ID";Results:
portal_key | project name | customer request type guid | customer request type name |
sds | SDS | 0e956422-5193-4ed3-8305-09720410a444 | Test |
sds | SDS | aa229e33-81e0-4e7d-908b-dc50cf1a6231 | Test |
hd | HD | 46d6141f-a6ba-486a-a989-d67be7f760d1 | Test Block |
hd | HD | 59c26ee0-f5d6-44fc-8f7d-19cf1f619486 | Test Accept |
c. In this scenario, I'm looking to set the customer request type to "Test Block" on the clone issue. The guid would be "<portal_key>/<request_guid>"
portal_key = hd
request_guid = 46d6141f-a6ba-486a-a989-d67be7f760d1
d. Save the automation rule and proceed with the test in your Test environment.
Troubleshooting
Automation rule does not work:
The automation rule triggers when transitioning an issue. Check if you use other triggers such as manual triggers to test the results.
Check the Audit log if you have seen any errors. Sometimes, you can see that the failure could be related to an incorrect customer request type guid.
The automation rule might be restricted to a single project. Please check the rule details to allow multiple projects and select all the related projects.
SQL results above might be different when you run on different Jira environments such as production and dev environments. Please verify the request type guid and portal key before implementing it in production.
