Automation rule | Store linked issue in a custom field text on Issue
This KB article will help in sharing the suggestions for the use case :
When an issue gets linked with any issue relation, let's say "Blocks" then store the issue key in the custom field "Text" type on the Parent issue.
Automation rules can be setup with different approaches for this use case. Here is one approach that you can explore:
Trigger: Issue linked Branch rule / related issues: Type of related issues: Current Issue Lookup issues: JQL: issue in linkedIssues({{key}}, "blocks") Edit issue: Select the desired custom field. Pass the value in the field: {{lookupIssues}}
Here is the automation rule configuration file for reference:
"cloud": true,
"rules": [
"id": 15126453,
"clientKey": "fcb18f79-08d6-35bd-9c47-b1e204f45645",
"name": "Add linked issue in the custom field",
"state": "ENABLED",
"description": "",
"authorAccountId": "6362284b01c2ff842c19db70",
"actor": {
"type": "ACCOUNT_ID",
"value": "557058:f58131cb-b67d-43c7-b30d-6b58d40bd077"
"created": 1696235484668,
"updated": 1696236596349,
"trigger": {
"id": "329691080",
"component": "TRIGGER",
"parentId": null,
"conditionParentId": null,
"schemaVersion": 1,
"type": "jira.issue.event.trigger:link",
"value": {
"linkTypes": [
"Blocks"
"children": [],
"conditions": [],
"connectionId": null
"components": [
"id": "329691082",
"component": "BRANCH",
"parentId": null,
"schemaVersion": 1,
"type": "jira.issue.related",
"value": {
"relatedType": "current",
"jql": "",
"linkTypes": [],
"onlyUpdatedIssues": false,
"similarityLimit": 40,
"compareValue": 0
"children": [
"id": "329691084",
"component": "ACTION",
"parentId": "329691082",
"schemaVersion": 1,
"type": "jira.lookup.issues",
"value": {
"id": "_customsmartvalue_id_1696236456463",
"name": {
"type": "FREE",
"value": "lookupIssues"
"type": "JQL",
"query": {
"type": "SMART",
"value": "issue in linkedIssues({{key}}, \"blocks\")"
"lazy": false
"children": [],
"conditions": [],
"id": "329691085",
"schemaVersion": 1,
"type": "codebarrel.action.log",
"value": "{{lookupIssues}}",
"children": [],
"conditions": [],
"id": "329691086",
"schemaVersion": 10,
"type": "jira.issue.edit",
"value": {
"operations": [
"field": {
"type": "NAME",
"value": "Link Key"
"fieldType": "com.atlassian.jira.plugin.system.customfieldtypes:textarea",
"type": "SET",
"advancedFields": null,
"sendNotifications": true
"children": [],
"conditions": [],
"conditions": [],
"canOtherRuleTrigger": false,
"notifyOnError": "FIRSTERROR",
"projects": [],
"labels": [],
"tags": [
"id": 44621159,
"tagType": "IS_RULE_UPDATED",
"tagValue": "true"
"ruleScope": {
"resources": [
"ari:cloud:jira:7bbd0f61-9cf7-46a8-a02c-5d635b174db8:project/10015"
"ruleHome": {
"ruleLifeCycleHome": {
"locationARI": "ari:cloud:jira:7bbd0f61-9cf7-46a8-a02c-5d635b174db8:project/10015"
"ruleBillingHome": {
"locationARI": "ari:cloud:jira-software::site/7bbd0f61-9cf7-46a8-a02c-5d635b174db8"
"writeAccessType": "UNRESTRICTED",
"collaborators": [],
"billingType": "NORMAL"
}INFORMATION
If you want to the issues in the hyperlink format then ensure that the custom field has setup Wiki Style renderer as an Active renderer for the field. You can check the KB article: How to update Active Renderer for the field to setup Active Renderer as Wiki Style.
