Automation Rule| Capture Bug issue count of backlog via Jira automation
When an issue is created of Bug issue Type, capture the count of the Bug backlog(not in DONE status) and estimate if the backlog is more than 5.
Automation configuration approach suggestion:
Trigger:
When issue created
Condition: Issue fields condition
Field: issuetype
Condition: equal
Value: "bug"
Lookup issues:
JQL : issuetype = "bug" and status != done
Advanced compare condition :
First Value: {{
lookupIssues.size}}Condition: greater than
Second value: 5 (you define any number that you want)
Then Log action:
Log message: {{lookupIssues.size}}
Sharing snippet for reference :
Suggestion
You can use send email action instead of Log action in case you wish to get the email notification.
