Automation for Jira rule creates corrupted issues with missing workflow actions
Issue creation via Automation for Jira fails as per the Automation for Jira Audit log randomly, but still corrupted issues with missing workflow actions are created.
This issue is a random issue and does not occur always but sometimes when multiple issues are created using Automation For Jira then this issue is observed.
The below error is found in the atlassian-jira.log when the issue is seen.
SdOffThreadEventJobRunner:thread-2 ERROR /servicedesk/customer/portal/1/create/67 [c.a.s.internal.util.SafeRunner] Unable to run event handler onIssueChangedEvent: IssueChangedEventImpl{changeItems=[com.atlassian.jira.issue.history.ChangeItemBean@29e2cbc3[fieldType=jira,field=assignee,from=<null>,fromString=<null>,to=JIRAUSER11226,toString= ,created=], author=Optional, comment=Optional.empty, issue=ITSMSD-29654, eventTime=, sendMail=true, spanningOperation=null} com.querydsl.core.NonUniqueResultException: Only one result is allowed for fetchOne calls at com.querydsl.core.support.FetchableQueryBase.uniqueResult(FetchableQueryBase.java:64) at com.querydsl.sql.ProjectableSQLQuery.fetchOne(ProjectableSQLQuery.java:398) at com.atlassian.jira.versioning.VersioningDao.lambda$getCurrentVersion$6(VersioningDao.java:152) at com.atlassian.jira.database.DefaultQueryDslAccessor.lambda$executeQuery$0(DefaultQueryDslAccessor.java:68) at com.atlassian.jira.database.DatabaseAccessorImpl.runInTransaction(DatabaseAccessorImpl.java:116) at com.atlassian.jira.database.DefaultQueryDslAccessor.executeQuery(DefaultQueryDslAccessor.java:67) at com.atlassian.jira.versioning.VersioningDao.getCurrentVersion(VersioningDao.java:147) at com.atlassian.jira.versioning.EntityVersioningManagerImpl.lambda$getIssueVersion$3(EntityVersioningManagerImpl.java:122)
There are multiple rows with the same issue version and history step with the same time stamp in the table issue_version,OS_HISTORYSTEP_prev,OS_HISTORYSTEP
select * from issue_version where issue_id in (SELECT issue_id FROM issue_version GROUP BY issue_id HAVING COUNT(*) > 1); select * from OS_HISTORYSTEP where id in (SELECT id FROM OS_HISTORYSTEP GROUP BY id having count(*) > 1); select * from OS_HISTORYSTEP_prev where id in (SELECT id FROM OS_HISTORYSTEP_prev GROUP BY id having count(*) > 1);
Please note: The query above is valid for PostgreSQL database. For other databases, the schema under which the table exists can be different. Please adapt the query as needed.
Run the below query to validate whether the primary key indexes pk_issue_version,pk_os_historystep_prev, pk_os_historystep are present or not
SELECT * FROM pg_indexes WHERE schemaname = 'public' AND tablename = 'issue_version' ORDER BY tablename, indexname; SELECT * FROM pg_indexes WHERE schemaname = 'public' AND tablename = 'OS_HISTORYSTEP' ORDER BY tablename, indexname; SELECT * FROM pg_indexes WHERE schemaname = 'public' AND tablename = 'OS_HISTORYSTEP_prev' ORDER BY tablename, indexname;
The primary key indexes
pk_issue_version
pk_os_historystep
for all the above mentioned tables were not present and due to that multiple duplicate entries were created in the above tables. The reason for which the primary key indexes were missing is not known.
It is recommended to raise a ticket with Atlassian for help on deleting the duplicates as it involves complex steps.
  • Take a backup of the database
  • Shut Down Jira
  • Run the below queries to delete the duplicate entries
DELETE FROM issue_version T1 USING issue_version T2 WHERE T1.ctid < T2.ctid -- delete the older versions AND T1.issue_id = T2.issue_id; DELETE FROM os_historystep T1 USING os_historystep T2 WHERE T1.ctid < T2.ctid AND T1.id = T2.id; DELETE FROM OS_HISTORYSTEP_prev T1 USING OS_HISTORYSTEP_prev T2 WHERE T1.ctid < T2.ctid AND T1.id = T2.id;
  • Then create the missing indexes
CREATE UNIQUE INDEX pk_issue_version ON public.issue_version USING btree (issue_id); CREATE UNIQUE INDEX pk_os_historystep_prev ON public.OS_HISTORYSTEP_prev USING btree (id); CREATE UNIQUE INDEX pk_os_historystep ON public.OS_HISTORYSTEP USING btree (id);
  • Restart Jira
  • Perform Full Reindexing and then everything should work as expected.
Updated on September 26, 2025
