Automation For Jira - How to clear the Parent Link field when an issue is moved to a new type
The context behind this article
Advanced Roadmaps is an application which comes with some custom fields such as Team, Parent Link, Target Start, Target End...
The Parent Link field links issues together based on the hierarchy configured for the Advanced Roadmap. For example, if the Epic issue type is ranked underneath the Initiative issue type, then Epic issues can be linked to Initiative issues via the Parent Link field, and the Epic issue will be considered a child of the linked initiative.
When issues that already have a parent link are moved to a new issue type (that belongs to a different level in the hierarchy), the Parent Link field remains untouched, which causes data discrepancy since the hierarchy levels are no longer respected.
For example:
let's assume that the hierarchy is configured with the following order: Initiative > Epic > Story
let's assume that issue ABC-111 is an Epic issue which is linked to the parent ABC-222 which is an Initiative issue
if the issue ABC-111 is moved to a new type such as a Story, the Parent Link will not be cleared, and will still point to the Initiative issue ABC-222
this will cause data discrepancy since Story issues can't be directly linked to Initiative issues
This issue is a known feature limitation, which is tracked in the open suggestion ticket linked: JSWSERVER-24811
The solution consists of 2 main steps.
Step 1 - Identify the ID of the Parent Link custom field
Let's identify the custom field ID of the Parent Link field ( this ID will be different in each Jira installation) by following the steps below:
Go to the page ⚙ > Issues > Custom Fields
Search for Parent Link
Click on ... > View next to the field
Pickup the ID at the end of the URL (this is the custom field ID), as shown in the example below:
Step 2 - Create the automation rule
Now it's time to create the automation rule. Note that you can:
either create the automation rule at the global level via the page ⚙ > System > Automation rules
or create the automation rule for the project:
For Jira 8.x, via the page Project Settings > Project Automation
For Jira 9.x, via the page Project Settings > Automation
Automation rule configuration:
WHEN: Field value changed
Field to monitor: Issue Type
For: All issue operations
IF: Advanced compare condition
First Value: Past the content below, after replacing XXXXX with the custom field ID found earlier:
Condition: does not equal
Second value: Empty
THEN: Edit issue
Do not select any field, and instead paste the content below in the Additional fields box, after replacing XXXXX with the custom field ID found earlier:
{ "fields": { "customfield_XXXXX":"" } }
Full Automation rule :
