Automation for Jira - How to automatically close an Initiative issue once all its Epics are closed
The purpose of this article is to provide a way to configure an automation rule that will automatically close an Initiative (or any other type of parent issue), once all its child issues (such as Epics) are closed.
For this solution:
We will assume that the Initiative issue and its child Epic issues are considered as closed when they are in the Status DONE
We will also assume that the parent/child relationship is configured as below in the Hierarchy Levels page that comes with the application Advanced Roadmaps For Jira:
The hierarchy levels are configured so that the Initiative issue type is a parent of the Epic issue type:
With such hierarchy level configuration, we will have the Parent/Child relationship described in the examples below:
The issue SCRUM-29 is a parent issue of the 2 Epics SCRUM-30 and SCRUM-31 (as shown in the Child Issues panel):
The issue SCRUM-30 (and SCRUM-31) child issues of the issue SCRUM-29 (as indicated in the Parent Link field):
If you are using different parent/child relationship in the Hierarchy Levels configuration with different issue types, it will be necessary to slightly adjust the solution provided in this KB article, based on your own configuration. Additionally, if you are using a different status than DONE to indicate that an issue is closed, you will need to change the automation rule slightly to reflect it.
Preliminary steps
Before configuring the automation rule, you need to first identify the ID of the Parent Link custom field, since this ID will be different depending on the Jira environment:
Go to ⚙ > Issues > Custom Fields
Search for the Parent Link custom field, and click on ... > View
Get the ID from the URL: it is custom field ID that is needed to configure the automation rule
Rule Configuration
The automation rule will be configured like this:
New Trigger: Issue transitioned
From status: leave blank
To status: Done
Make sure to change the status to the one used in the workflow when an issue is closed (for example: Closed, Resolved, etc...)
New Condition: Issue fields condition
Field : Issue type
Condition : Equal
Value : Epic
Branch Rule / related issues
Type of related issues: JQL
key in parentIssuesOf("{{triggerIssue.key}}")Untick the option Only include issues that have changed since the last time this rule executed
Rule restricted to projects: <Your project name here>
In the Branch:
New Condition: Issue Field Condition
Status : Status
Condition : Does not equal
Value : Done
New Related issues condition
Related Issues : JQL Issues
Related issues JQL: (Replace XXXXX with the Custom Field ID of the Parent Link field, based on the preliminary steps)
"Parent Link" = {{triggerIssue.customfield_XXXXX}}Condition: "All match specified JQL"
Matching JQL: (change the status to the one indicating that an issue is closed)
status = Done
New Action: Transition issue
Transition the issue by: Selecting the destination status
Destination status: Done
Make sure to change the status to the one used in the workflow when an Epic/Initiative is closed (for example: Closed, Resolved, etc...)
The automation rule will look like this:
