Running Atlassian products on Docker might fail during startup because of Docker Engine version
Running an Atlassian application (Bitbucket, Confluence, Crowd, Jira Software or Jira Service Management) on a Docker container fails during the application startup.
This problem only occurs with a more recent image. Trying to start the same application with an old image works fine.
The issue only occurs if the Docker Engine version is lower than 20.10.10.
The remainder of the document will help identifying if you are running into this problem and the remediation actions.
The following commands may help identifying if affected by this issue.
docker version
docker logs --follow <container-id>The Docker version installed is lower than 20.10.10.
In this example we validated the problem with Docker version 20.10.8.
ubuntu@ip-10-100-10-10:~$ sudo apt list --installed | grep -i docker
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
docker-ce-cli/focal,now 5:20.10.8~3-0~ubuntu-focal amd64 [installed,upgradable to: 5:20.10.17~3-0~ubuntu-focal]
docker-ce-rootless-extras/focal,now 5:20.10.8~3-0~ubuntu-focal amd64 [installed,upgradable to: 5:20.10.17~3-0~ubuntu-focal]
docker-ce/focal,now 5:20.10.8~3-0~ubuntu-focal amd64 [installed,upgradable to: 5:20.10.17~3-0~ubuntu-focal]
docker-scan-plugin/focal,now 0.17.0~ubuntu-focal amd64 [installed,automatic]
ubuntu@ip-10-100-10-10:~$ docker version
Client: Docker Engine - Community
Version: 20.10.8
API version: 1.41
Go version: go1.16.6
Git commit: 3967b7d
Built: Fri Jul 30 19:54:27 2021
OS/Arch: linux/amd64
Context: default
Experimental: true
Server: Docker Engine - Community
Engine:
Version: 20.10.8
API version: 1.41 (minimum version 1.12)
Git commit: 75249d8
Built: Fri Jul 30 19:52:33 2021
Experimental: false
containerd:
Version: 1.6.6
GitCommit: 10c12954828e7c7c9b6e0ea9b0c02b01407d3ae1
runc:
Version: 1.1.2
GitCommit: v1.1.2-0-ga916309
docker-init:
Version: 0.19.0
GitCommit: de40ad0
ubuntu@ip-10-100-10-10:~$Checking the Container logs shows one of the following errors.
Starting Bitbucket on Docker may fail with an error similar to the below.
JRE_HOME '/opt/java/openjdk' is Java
Atlassian Bitbucket requires Java 8 to run
Set JRE_HOME to a Java 8 JRE and try again
Startup has been abortedExpand to see full output...
ubuntu@ip-10-100-10-10:~$ docker pull atlassian/bitbucket-server:7.21.1
7.21.1: Pulling from atlassian/bitbucket-server
405f018f9d1d: Already exists
9c045aca8dd9: Already exists
efd1c42ec938: Already exists
35541a1051f3: Already exists
916f58ac27a6: Pull complete
6b85b42cfe3f: Pull complete
7138cd25743b: Pull complete
a15123125861: Pull complete
ac6afafd9658: Pull complete
8c62a84e3977: Pull complete
53f8e904b5bf: Pull complete
ed2eafe9be0a: Pull complete
Digest: sha256:56dcd54599c66ba6d9d715a9d36b5346d591c7867e6db24a3fd630099ddbfe51
Status: Downloaded newer image for atlassian/bitbucket-server:7.21.1
docker.io/atlassian/bitbucket-server:7.21.1
ubuntu@ip-10-100-10-10:~$ mkdir bb-home7211
ubuntu@ip-10-100-10-10:~$ docker run --name="bitbucket-7211" \
> -v /home/ubuntu/bb-home7211:/var/atlassian/application-data/bitbucket \
> -d -p 7990:7990 -p 7999:7999 \
35e266b547799f72df4bd3aeb7afa6ebc2f4d8947e507df7220551ee649c5757
ubuntu@ip-10-100-10-10:~$ docker logs --follow bitbucket-7211
WARNING:root:######################################################################
WARNING:root:Starting Bitbucket with embedded search service. Note that this is
not a recommended configuration and is known to have issues with
clean shutdown. Ideally OpenSearch (previously Elasticsearch) should
be started in a separate container/pod.
INFO:root:User is currently root. Will change directory ownership and downgrade run user to bitbucket
INFO:root:User is currently root. Will downgrade run user to bitbucket
INFO:root:Running Bitbucket with command '/opt/atlassian/bitbucket/bin/start-bitbucket.sh', arguments ['/opt/atlassian/bitbucket/bin/start-bitbucket.sh', '-fg']
ubuntu@ip-10-100-10-10:~$Confluence
Starting Confluence on Docker may fail with an error similar to the below examples.
Using Java: /opt/java/openjdk/bin/java
[0.019s][warning][os,thread] Failed to start thread - pthread_create failed (EPERM) for attributes: stacksize: 1024k, guardsize: 4k, detached.
# There is insufficient memory for the Java Runtime Environment to continue.
# Cannot create worker GC thread. Out of system resources.Using CATALINA_PID: /opt/atlassian/confluence/work/catalina.pid
/opt/atlassian/confluence/bin/catalina.sh: 1: eval: Syntax error: "(" unexpectedCannot find /opt/atlassian/confluence/bin/setclasspath.sh
This file is needed to run this programCrowd
Starting Crowd on Docker may fail with an error similar to the below.
[0.020s][warning][os,thread] Failed to start thread - pthread_create failed (EPERM) for attributes: stacksize: 1024k, guardsize: 4k, detached.
# Cannot create worker GC thread. Out of system resources.Jira Software or Jira Service Management
Starting Jira on Docker may fail with an error similar to the below.
Server startup logs are located in /opt/atlassian/jira/logs/catalina.out
/opt/atlassian/jira/bin/check-java.sh: line 31: [: -ne: unary operator expected
/opt/atlassian/jira/bin/set-gc-params.sh: line 5: [: -ge: unary operator expected
Unrecognized VM option 'UseGCLogFileRotation'
[0.000s][warning][gc] -Xloggc is deprecated. Will use -Xlog:gc:/opt/atlassian/jira/logs/atlassian-jira-gc-%t.log instead.
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.Cause
Atlassian (Docker) images were recently updated and now require Docker Engine version >= 20.10.10.
The issue is related to the update to the Adoptium OpenJDK and incompatibilities with older versions of the Docker Engine.
Refer to each product's Docker Hub page:
Bitbucket: https://hub.docker.com/r/atlassian/bitbucket-server
Confluence: https://hub.docker.com/r/atlassian/confluence
Jira Software: https://hub.docker.com/r/atlassian/jira-software
Jira Service Management: https://hub.docker.com/r/atlassian/jira-servicemanagement
Upgrade the Docker Engine to version 20.10.10 or a more recent one.
Refer to Docker Engine release notes for more information about Docker versions.
