How to find unused Shared Teams on Advanced Roadmaps for Jira Data Center
As an admin, you may want to cleanup Shared Teams (also known as Public teams) to reduce cluttering or in preparation for a migration.
This article aims to give you database queries to track how many issues and plans are associated to each Shared Team.
Any version of Jira Software Data Center or Server with Advanced Roadmaps (bundled or installed as an app).
For some context, Jira stored all Teams (including private teams) on AO_D9132D_PLANTEAM database table.
There's a column named Shareable which we can filter true only for the purpose of this solution.
Unlike other custom field which have their data stored on customfieldvalue table, Advanced Roadmaps and its exclusive fields are stored on entity_property where entity_id is the issue ID and the team value is on json_value column.
The last database table used is AO_D9132D_PLANTEAM which contains the association between plans and teams.
SQL queries below were tested in Postgres database. If you are using another database, update the syntax compatible to your database.
Shared Teams not associated to any issues
Remove the "having" condition if you'd like to get a count of issues associated to them.
SELECT t."ID",t."TITLE",count(ep.id) AS team_id FROM "AO_82B313_TEAM" t LEFT JOIN entity_property ep ON ep.property_key = 'jpo-issue-properties' AND ep.json_value LIKE ('%"team_id":"' || t."ID" || '"%') WHERE t."SHAREABLE" = true group by t."ID" having count(ep.id)=0;
Shared Teams not associated to any plans
Remove the "having" condition if you'd like to get a count of plans associated to them.
SELECT t."ID",t."TITLE",count(pt."ID") AS team_id FROM "AO_82B313_TEAM" t LEFT JOIN "AO_D9132D_PLANTEAM" pt ON t."ID" = pt."TEAM_ID" WHERE t."SHAREABLE" = true group by t."ID" having count(pt."ID")=0;
Shared Teams not associated to any plans or issues
Here you can remove either/or the having conditions at the end if you'd like to filter by one condition only and get the counts for the other.
SELECT t."ID",t."TITLE",count(pt."ID") AS PlanAssociationCount,count(ep.id) AS IssueAssociationCount FROM "AO_82B313_TEAM" t LEFT JOIN entity_property ep ON ep.property_key = 'jpo-issue-properties' AND ep.json_value LIKE ('%"team_id":"' || t."ID" || '"%') LEFT JOIN "AO_D9132D_PLANTEAM" pt ON t."ID" = pt."TEAM_ID" WHERE t."SHAREABLE" = true group by t."ID" having count(ep.id)=0 and count(pt."ID")=0;
Here's the documentation for reference around managing Teams in Advanced Roadmaps:
Updated on September 25, 2025
