Cannot Create Advanced Roadmap Plan due to error Your plan contains more than 100 projects
When attempting to create a plan in Advanced Roadmaps plan creation fails with the following error:
Your plan contains more than 100 projects. Remove issues sourcess or use the section below to refine your plan. Environment
Jira Data Center 9+
In addition to the error during plan creation, the following error will be present in the application logs (atlassian-jira.log*)
/rest/jpo/1.0/plan/setup/projects [c.a.r.c.r.provider.exception.DefaultExceptionMapper] java.lang.RuntimeException: Could not find suitable distance for rank.
com.atlassian.rm.common.env.EnvironmentServiceException: java.lang.RuntimeException: Could not find suitable distance for rank.
Caused by: java.lang.RuntimeException: Could not find suitable distance for rank.To further diagnose this issue, you will want to run the following database queries:
SELECT * FROM "AO_60DB71_LEXORANK" WHERE "TYPE" IN (0, 2);
SELECT * FROM "AO_60DB71_LEXORANK";The output will likely look something like this where the Rank table has 2 minimum and maximum markers:
FIELD_ID | ID | ISSUE_ID | LOCK_HASH | LOCK_TIME RANK | TYPE | BUCKET | |
-859340285902835 | 27 | -9223372036854775808 | NULL | NULL | 0|000000: | 0 | 0 |
-859340285902835 | 28 | -9223372036854775808 | NULL | NULL | 0|000000: | 0 | 0 |
-859340285902835 | 29 | 92233772036854775807 | NULL | NULL | 0|zzzzzz: | 2 | 0 |
-859340285902835 | 30 | 92233772036854775807 | NULL | NULL | 0|zzzzzz: | 2 | 0 |
⚠️ Please test this procedure in a test instance before applying it in your production instance. Due to database modifications, please make sure to take a database backup in case a rollback in necessary.
Stop Jira on all nodes
Backup the database
Run the SQL statement to remove both the minimum marker with the highest ID and the maximum marker with the highest ID. In the above example, this is IDs 28 and 30:
delete from AO_60DB71_LEXORANK where ID in ('28','30');Restart Jira on all nodes
Perform a Full/Locked Re-index
After the re-index is completed, please access the Lexorank Management page and trigger re-balance.
Go to Administration (
) →System → Lexorank Management
Once the re-balance is done, please check to see if the issue is resolved and the Advanced Roadmaps plan can be created.
